Fees charge in your area
Intonation, Compensation, Frustration
Neck reset $350 ( unbound) $400 Bound
Refret $10 $15 ( bound board per fret )
Reglue bridge $75 ( removal and reglue )
Nut ( $50 )
Saddle ( $50 )
Slotting bridge ( $50 )
Fret dress ( $50 to $70 )
Install Pick up ( K&K) $40
Retop $1000
Conversions $2500 on up
Re: Fees charge in your area
Neck reset- DT $200; M&T $75 (unglued); $125 (glued)
Refret $150
Reglue bridge $50 (remove and reglue)
Nut $40; 12 string $55
Saddle $30 uncompensated; $40 compensated
Slotting bridge $35; Fill and re-rout $50
Fret dress $60 and up (instrument dependent)
Install Pick up (K&K) $125 (includes Pure Mini pickup)
Crack repair $5-$25 per inch (type dependent)
Currently I'm the least expensive in the Raleigh/Durham NC area.
watergunn
Post by watergunn »
Thanks for the replies.
So far all of mine have been just the basic adjustments at the nut and saddle.
I do appreciate the info.
Holy Batman!
According to these fees, I've saved a ton of money on doing my own setups, adjustment of intonation including filing the saddle, replacement and adjustment of saddle and nuts, 8" crack repair and refinish of the entire back, truss rod adjustments, not to mention the restoration of an old classical with a warped top.
Maybe I should become a guitar tech...
there is always room for another good tech
