Build #2: StewMac Mahogany Dreadnought
rcnewcomb
Re: Build #2: StewMac Mahogany Dreadnought
Post by rcnewcomb »
Trimming the edges of the top and back
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
After sanding but before cutting the channels for the binding.
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
I had Kathy Matsushita help me with cutting the channels for the purfling, binding, and the end wedge.
Fortunately the dark spot on the top bass shoulder will get removed by the purfling channel
Fitting a plug in the neck slot so the router can flow over that spot
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
Using Kathy's setup to cut the channels
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
Checking the fit
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
Cutting the end wedge
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
First look at the purfling as the tape is coming off
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
First time using a bending iron
- Randall Newcomb
rcnewcomb
Post by rcnewcomb »
I'm trying a set of bindings wrapped in aluminum foil to try and reduce scorching. I'm then fitting the bent pieces into the form. They will stay there until next week when I can work on the instrument again.
- Randall Newcomb
kmatsu
Post by kmatsu »
rcnewcomb wrote:I'm trying a set of bindings wrapped in aluminum foil to try and reduce scorching.
I think maybe using the foil was what allowed it to scorch; the foil is just tranferring the heat, just as the metal bending iron is. Putting a damp piece of cloth on the bending iron as you bend would probably have kept it from scorching (and would provide more steam, also) -- maybe you didn't get my email where I had mentioned this? :)
