Binding a fretboard... how do you?
Re: Binding a fretboard... how do you?
Post by kencierp »
Jim -- Pretty slick process! I too will give it a try.
JRHall
Post by JRHall »
I can't take credit for the origin, (don't tell anybody, but I saw John Hall do it). It's one of those forehead smackers, Like you said, duh.
Another possibility - from the 'net.
I will get you a pic of my jig as soon as I get a new camera
Post by kencierp »
I see now that this device is pretty common and found often on the Internet --- Jim, thanks for introducing the idea to the forum. Here's my version, all surfaces are covered with clear plastic packaging tape so nothing will stick to it even CA.
You are missing one point The fence area or rail should be low enough so you can do your fretting in this jig. Also on the end you want a small block so you can use a wedge to clamp off that part of the binding .
If you are using plastic binding , you start at the sound hole side , heat the binding to bend it , and work around the corner.
Pic will follow as soon as camera arrives
Post by kencierp »
Personally I would not do fretting in this fixture I'd use my normal rock solid fretting station. But that's just me.
if you do wood binding you will be fine , platic you will knock it loose and the fixture wedges the board tight so you can fret without fear of bounce .
I agree Ken that you need a firm footing for hammer fretting
Tom West
Post by Tom West »
With a wide blank,cut the binding strips from the blank using a thin kerf saw,THEN cut the fret slots.
Tom
JRHall
Post by JRHall »
[quote="kencierp"]I see now that this device is pretty common and found often on the Internet --- Jim, thanks for introducing the idea to the forum. Here's my version, all surfaces are covered with clear plastic packaging tape so nothing will stick to it even CA.
Yeah, I forgot the part about laying a piece of wax-paper over the jig before you insert the fretboard.
Jim
