Go-Bar Deck
Re: Go-Bar Deck
Post by   »
3/4" ply is what I used.
Chuck73
Re: Go-Bar Deck
Post by Chuck73 »
I used 2'x2' squares of MDF and some 2x4 s for the deck and those orange fiberglass driveway markers cut in half for the rods.
Re: Go-Bar Deck
you must be careful of MDF as when it fails and it will it is often catastrophic . I made on with it once the stress exceeded the support the corners broke. Plywood is the better option. When you think about it 20 sticks at 10lbs is 200 lb.
mnmusic
Re: Go-Bar Deck
Post by mnmusic »
I was thinking of 2' x 2' x 3/4" plywood doubled up for both the top and bottom. Does that sound reasonable? So 1 1/2" thick for the top and bottom of the go-bar deck.
Thanks,
Re: Go-Bar Deck
Post by   »
Unreasonable. 1 1/2" thick is overkill. 3/4" is plenty.
mnmusic
Re: Go-Bar Deck
Post by mnmusic »
tommyboy wrote:Unreasonable. 1 1/2" thick is overkill. 3/4" is plenty.
SM shows 4 layers of 3/4" plywood for their go-bar deck bottom and 2 layers for the top. Now that's unreasonable.
http://www.google.com/url?sa=i&rct=j&q= ... 1187642012
Re: Go-Bar Deck
Post by   »
I'm not sure I get your point....
mnmusic
Re: Go-Bar Deck
Post by mnmusic »
tommyboy wrote:I'm not sure I get your point....
I guess I'm just trying to point out my confusion. You say 3/4" is enough yet Stewart McDonald says to use 4 layers of 3/4" plywood for their go-bar deck bottom and 2 layers for the top. That's a huge difference. I'm just confused, that's all (doesn't take much these days).
Re: Go-Bar Deck
I will say that NOT ALL PLYWOOD IS CREATED EQUAL.
get a good cabinet grade and one 3/4 in layer is all you need. I use baltic birch myself.
why use more than you need to
Re: Go-Bar Deck
Post by   »
Ed, you may be falling prey to Paralysis by Analysis. Too many opinions/suggestions. Go with what makes you comfortable.
However, I think if you use a GoBar to do a glue-up that will distort a 3/4", 2'x2' piece of ply you're doing something way wrong.
-tommy
