MS D-18
Re: MS D-18
Here's the rim with the top flat (I'll be putting in the slope later) and the back to a 12" radius.
Re: MS D-18
I use this sanding block for all the brace ends that I will be inlet. It is 0.10" deep. The tape on the edges is to compensate for the sand paper thickness.
Re: MS D-18
Sanding the X braces to a 25' radius and the top bracing layout. I'll glue it up tomorrow.
Re: MS D-18
I cut the side reinforcement strips and will chamfer them before gluing them in.
Re: MS D-18
I like to use dowel register pins to locate my top, so before I glue in the top braces I locate the hole positions using my template and 1/4" dowel centering pins, center the template, mark and drill. To be sure I will have my neck tenon centered to the mortise properly I use this tip from John Hall (I have it bookmarked for easy reference). My block has a 1/16" difference from side to side:
http://www.youtube.com/watch?v=OhF48s9UAN4&feature=plcp
Edit: That's a great 1937 Martin D template I got from John as well. Cut Perfectly.
Re: MS D-18
Here it is with the pins in place and all centered up.
Re: MS D-18
Getting supplies ready to glue up the side reinforcement strips but first I have to bevel them on the belt sander. (I have some ribbon but I'm going to use that on another project).
Re: MS D-18
Now for the glue up, I like to get these as straight as possible. That's going to be just about it for this morning because I have to take some time out to go see "The Hobbit" and then take my Honey out for dinner.
Re: MS D-18
Side reinforcements are in. I like to line them up with the back bracing. I think it gives them a nice clean even look. Now, off to see "The Hobbit" and diner afterwards at Outback.
Re: MS D-18
work is looking good. That template is being put to good use. I like the photo essay and I am sure many novice builders will benefit from this
thanks again for posting Tim
john
