warped unjoined back plates
jrc127
Post by jrc127 »
I have a nice set of ribbon African Mahog. that I stored flat in my shop. The unjoined plates have slightly warped. I'm sure I can flatten them but want to make sure of the procedure. Like so?: wet them on the concave side (inside curve) and put some weight on them. Will that work?
James Cowhey
Cornwall, PA
Re: warped unjoined back plates
DO NOT ADD WATER
lay them with the cup side down. If you use a cloths iron on med heat you can iron the up side and get them flat then thickness them Keep them flipped for a few weeks then brace. Even a slight warp will work out once braced.
jrc127
Post by jrc127 »
Thanks, John. Will do.
James Cowhey
Cornwall, PA
ColestineGuitar
Post by ColestineGuitar »
Hah! I shall do the same with the "potato chipped" indian rosewood I bought. I was gonna get them wet, then put them under weights on the top of a cooling wood stove, once it had cooled to less than 300 degrees F.
(thanks, John)
it they are real bad you can use a cloths iron and iron them just before gluing braces. I have used that trick many times. I now have a heat blanket and treat them with med heat for about 20 min at 225 F
tippie53 wrote:it they are real bad you can use a cloths iron and iron them just before gluing braces. I have used that trick many times. I now have a heat blanket and treat them with med heat for about 20 min at 225 F
What size blanket are you using for that?
I have 18 by 24 in blankets made for this
