Build #3: sitka/black walnut 000
Re: Build #3: sitka/black walnut 000
Good work Neil
You're almost there
That's alot of glue squeeze out around the bridge. I hope you cleaned that off before it hardened?
You're almost there
I did clean it off with a slightly damp sponge and them I used a chisel when it started to stiffen. I didn't think I used that much glue really. I'm hoping that that means it will stay put!
Ha ha I think it will.
You'll be playing tunes soon
I hope so, but the drop in saddle I bought is too thick and the bone bridge pins I ordered are still a day away. I’m actually relishing going through the setup process.Kevin Sjostrand wrote: ↑Wed Sep 10, 2025 11:52 pm Ha ha I think it will.
BTW for comparison I went to my local Martin dealer to try a Custom Shop 000-28 just to see what to shoot for. I’ve got a LOT of work ahead of me!
It will be a great guitar. For your saddle, I actually like them a little too thick, so I can sand them down for a no-wiggle fit. I use progressive grits of wet-dry sandpaper (using it dry) on a piece of plate glass, rotating end to end and side to side frequently to keep it flat. I made up a simple sanding device that is a block of wood with a wood rim on all four sides, lower than the finished saddle thickness, so there is a recess for the saddle blank to lie in. It makes it easier on the fingers when sanding-you push the block back and forth, and the saddle blank underneath gets sanded. Bruce W.
rcnewcomb
Do you have a photo?I made up a simple sanding device that is a block of wood with a wood rim on all four sides, lower than the finished saddle thickness, so there is a recess for the saddle blank to lie in.
- Randall Newcomb
Here it is - in all its splendor . . . . I have sometimes put a shirt cardboard shim in the bottom if I am doing a thinner saddle. You could also customize it for certain sizes if you make your saddles consistent (mine tend to be all one-offs). And with a larger recess you could do more than one saddle at a time, which might give flatter results.
Bruce W.
Bruce W.
I managed to sand it to fit using a piece of polished marble that was supposed to be a backsplash for a bathroom vanity. I also got the bridge pins today and reamed out the bridge pin holes so that they now fit. Now the only issue I’m having is dealing with a botched nut slot. Ugh.
TEETERFAN
Ha, we got a new bathroom vanity installed and all the scraps became assorted sanding blocks.
Kevin Doty
Kansas City
Kansas City
These last few steps are more of an exercise in patience than I appreciated! In particular, getting the finish right almost requires wrapping the top in bubble wrap and wiping it with endless progressive grits of wet/dry sandpaper.
Also, I have a confession: I scuffed the top up somewhat while fitting the bridge and need to Gluboost all the little dings I made in the area that stick out like a sore thumb. On my next build I'll be focusing on getting everything sanded to profile BEFORE I apply any finish. This may not be news to many of you, but even after 15 years since starting my first build I'm still a newbie.
Finally, how much of a sin is it I have to shim the nut because the slot is too wide? I've also been working on leveling/squaring it up with the end of the fretboard. I'm sure I'll have to get creative to address any problems with intonation but I'll cross that bridge when I get to it. I'll have to sacrifice a set of strings, but that's been par for the course for me.
*sigh* it's times like these I wish I could get away for a week and take a class with one of you master luthiers. I could certainly use a vacation from the family drama of having disabled and elderly loved ones who demand attention and hit me with things out of left field. Regardless, when this one is done I envision taking it to my mom's home and torturing them all with my best achy breaky version of "Wagon Wheel" and "Take Me Home Country Roads!"
