Fret Tang Size
scamp
Fret Tang Size
Post by scamp »
I want to purchase some fret wire for my next build.
I purchased a fret slotting jig and fret saw so I could make the fret boards myself.
The fret saw that came with the jig is designed to make a 0.023" fret slot width.
So... what is the best tang thickness for the frets.
I was looking at purchasing fret wire that comes in three different tang widths.
0.185 inch 0.195 inch and 0.0205 inches.
Does anyone have a recommendation on which is best?
Re: Fret Tang Size
jwscar 4380 0195 should be fine
scamp
Re: Fret Tang Size
Post by scamp »
tippie53 wrote: Thu Oct 26, 2023 4:36 pm jwscar 4380 0195 should be fine
Thanks John. Can I get this from Blues Creek and can you put a 16 inch Martin radius on it?
Re: Fret Tang Size
yes we carry it
bftobin
Re: Fret Tang Size
Post by bftobin »
It's very important to match your fret tang to the saw kerf. The wire John is recommending for you is ideal. I have several fret saws that cut different kerfs. On some guitars I cut a thin kerf so I can use 0.019 tangs and if the guitar needs refreting in the future, a different tang size may be needed. If your slot is too wide, it can cause a forward bow in the neck, and if the tang is too narrow, It may still work but will cause a back bow in the neck. I've made both mistakes at one time.
Re: Fret Tang Size
ok fretting 101
My best advice is not to fret a fretboard off the neck. I do all my fretting after the guitar is done.
tools you need
2 containers with about 5 lb of shot in each
A hammer I use a cobblers chasing hammer
Nippers and straight edge
So to get the best line of the fret plane use the weight on the shoulders of the guitar as you fret. I try to get about .010 curve in a neutral state of the truss rod.
thats the secret.
compression fretting is something else that is used on non adjustable neck reinforcement
