First guitar build
Jhunt
First guitar build
Here is a blog that will provide a brief recap of my first guitar build. It is the blues creek guatemalan rosewood b/s kit.
First, I went through the materials in the kit.
Next, I dry fit the side panels into a blues creek mold. From there I added the kerfing to one side and secured with 1” spring clamps. Then the heel block was screwed into the mold. That was all I had time for today.
TEETERFAN
Re: First guitar build
Well, you’re off and running! Looks good so far. I see you got plenty of clamps, that helps. Good luck with your build and thanks for the update!
Kevin Doty
Kansas City
Kansas City
BlindBo
Welcome to the “Rabbit Hole”. Before you know it you’ll have 2 or 3 more kits under your belt. Then comes thickness sanders, side benders, and before you know it, you’ll be looking at CNC machine tools!😱
The really good news is that you started with a guy who builds first class kits and is a wealth of knowledge he gladly shares. I’m sure I speak for all of us in wishing you the best of luck and enjoy your new adventure!
Jhunt
Today’s update:
Finished the kerfing and top bracing.
Jhunt
Believe it or not I already bought the lmi side bender. My optimism/ocd personality led me to buy the tools I’ll need to build one from scratch. That said, I don’t own a thickness sander or cnc yet, both would be nice to have!BlindBo wrote: ↑Thu Aug 24, 2023 6:32 pm Welcome to the “Rabbit Hole”. Before you know it you’ll have 2 or 3 more kits under your belt. Then comes thickness sanders, side benders, and before you know it, you’ll be looking at CNC machine tools!😱
Jhunt
I'd get a thickness sander before a CNC. While I use my CNC occasionally, I find I use my thickness sander ALL the time. It's homemade, and 9" wide, so it's limited in capability. Sanding a top or back to thickness 1/2 at a time is not the greatest way to go about it, but it sure beats doing it all by hand.
Another thing to think about, while you're dreaming of equipping your shop, is a milling machine. My dream machine would be a Jet JVM-836, but they're now over $9,000.
rcnewcomb
or you could add a sanding attachment to your CNC
[youtube]https://youtu.be/xC1VzMVhY5M?si=piP5U4ER6KxN2W3s[/youtube]
- Randall Newcomb
That's an interesting idea. One would definitely need a vacuum table to keep the wood flat though,and my CNC only goes to 12" wide so I still couldn't do a whole top or back.
BlindBo
I bought a 10” Jet and use it all the time and don’t have a CNC machine. While keeping the table level for sanding back and top pieces can be an inconvenience, it’s doable with careful attention. Where it really shines is doing small pieces, like bracing, shims, and pearl popsicle sticks. I use it a lot and consider it an important shop tool.
