Local Wood
carld05
Local Wood
Back in January Morecowbell asked about using local wood. Here are the parlor and prairie state I built from the wood off my property. Ponderosa Pine tops with some staining and a few worm holes, White Oak backs and sides and Manzanita fretboards, pinless bridges, binding and peghead veneer. The neck were laminated, White Oak with Manzanita down the middle.
Re: Local Wood
Awesome! I bet your feeling of satisfaction is off the scale.
