I assume most of the experienced builders already know this, so , I am posting this for the less experienced folks like me . I am building a L-OO for a friend and have a gorgeous set of sides and backs in deep red mahogany. The pores in this wood are so deep that it took four coats of aqua fill to level them. I sanded them flush after each application. Upon applying the base coats of lacquer, I noticed, dull, off-white specs in some of the pores. Due to my limited vision, I did not see them until the lacquer was applied. I tried several ways to correct this, and was unable to get them out. so, I’m now calling it a finish “enhancement“. 😳
While working with another piece of the mahogany today, I discovered that when sanding the aqua fill the dust gets into the unfilled portion of the pores and is not removed by wiping with Naptha and then a tack cloth. Then the next coat just locks it into the bottom of the pores.
So, today after each sanding, I blew the piece off with 90 psi air. Voila, no more dust. This is going to be my SOP from now on unless I come up with a smarter approach.
Hope this helps someone.
Pore Filling Issues
BlindBo
TEETERFAN
Re: Pore Filling Issues
Thanks for the great tip. I am planning on using that pore filler on an upcoming project and I will keep that in mind.
Kevin Doty
Kansas City
Kansas City
The spots usually indicate that the aqua coat isn't completely dry, especially if it's applied heavily, and without sealing the wood first. I had the same problem when I first started using Aquacoat. Unfortunately, the only fix is to sand it out completely, and start again.
You have to seal the wood before using Aquacoat. I choose to use a couple of coats of shellac. Then, you apply it thinly, working it into the pores. Some folks use a "squeegee" method; I just use small amounts on a paper towel. It dries in about 30-45 minutes. Then sand level. I blow it off, or use naphtha on a cloth to clean the dust. Repeat as necessary. You don't necessary have to fill 100% of the pores. Your finish will complete it.
After a rough start with Aquacoat, it's now the only pore filler i use. BTW, you can dye it using something like Transtint.
