Neodymium Magnets
Neodymium Magnets
How strong are your magnets, if you use them? How many pounds pull do you use?
Re: Neodymium Magnets
most that I use are in the 10lb range I have a special one that had 250 lb
that actually pulled itself apart and there was a funny story with it.
I had 2 of them and they pulled out of my had think about that 2 250 lbs pulls that is yes 500 lb the 2 together were maybe about 300lb but between them were tough. as I was at my bench things like chisels and razor blades came flying
I no longer have them
I saw a 250#. Thought it was a bit much. So, only 10 pounds. Okay. Thanks.
the ones I get are these
https://www.amazon.com/TRYMAG-Magnets-W ... 33&sr=8-10
https://www.amazon.com/THCMAG-Neodymium ... 02&sr=8-20
