Winter blues
jread
Winter blues
Post by jread »
The RH in my house dipped in this freeze snap quickly to about 35% from 45-ish.
Here's a build of mine about a year old: The bridge just popped up and the top crack is from bridge to tail block.
I feel this crack is was probably due to the humidity drop, sure but this glue joint was flawed. The glue line was more visible than my normal work and I let had it go. Well, 1 year later, this is what happened.
I know how to humidify to close and glue crack and reset the bridge.
But, I'm considering drastic measures such as replacing the top. I had hoped to sell it as new. I don't think I want to sell it even if repaired it's just going to be a long repaired crack which I think will prob open again. I think this joint is gonna be an issue going forward. Any thoughts on that?
Re: Winter blues
you are correct humidity caused the crack and if you notice the grain that is torn along the glue joint shows you had a good glue joint.
I run my humidifier set to 40% when its real dry getting 50% is very hard and anything about 37% is safe
jread
Re: Winter blues
Post by jread »
Thanks. I haven’t been measuring this room. Perhaps it crashed. Addressing. Thanks.
Re: Winter blues
I noticed that also, the glue joint looks to have held.
How about fix it and keep it and make the next one to sell?
Merry Christmas too!
jread
Re: Winter blues
Post by jread »
That settles it, Kevin. Keepin it. Merry Christmas me. I've posted this one here, it's the Rosewood OM slot head I made. It's the only build out of 23 now that I've made without knowing who it was for. I guess I know now.
I've hung it with a bag with a sponge in a plastic container w/ holes. We'll see how well I can get it to close up. Also cranked up the humidifier. I hadn't realized how much we crashed here.
Happy Holidays to everyone.
Bob Gleason
Re: Winter blues
Post by Bob Gleason »
Probably 20 years ago I sent a 000 size guitar from here in Hawaii to a player in New York in the Winter. It took only a few days for the top to develop a couple of cracks from the bridge to the tail and the top to sink so much as to make the guitar unplayable. When I got the guitar back, you could drop dimes through the cracks! It was a real learning experience. Anyway, I took the guitar back. Within a few days of just sitting in higher humidity, the cracks completely closed up. I played that guitar for many years without having to do any repairs on the cracks. Along the way the guitar suffered further damages, so I no longer have it, but it was an interesting experience. Happy Holidays!-Bob
Re: Winter blues
the big thing is to know what the RH is. Many hygrometers are inaccurate . You need to look on you tube for ways to calibrate your Hygrometers DO NOT ASSUME THEY ARE CORRECT.
The biggest piece of misinformation is maintaining 50% humidity. To be honest
if you can hold 37% to 42% in winter you win . I just had a customer that over humidified a guitar because his Hygrometer said it was 15%. He is in NY city. Most high rises have ventilation and maintain RH. The have City steam so its easier to heat and control RH>
I told him to get a certified Hygrometer
https://www.amazon.com/Cigar-Oasis-Hygr ... C93&sr=8-2
then use this system
https://www.youtube.com/results?search_ ... hygrometer
jread
Re: Winter blues
Post by jread »
good and timely info. I notice the cracks have closed to near invisible after a few days w/ some humification. I still see the thin line in the shellac. Since they are mine and not vintage so I may push some glue into the cracks, then lightly sand w/ 1000 or 1500g down the line and then refresh the shellac. I think the center seam on this guitar will just be more visible than most but certainly not a big deal.
