DIY Duplicating Rig
BEJ
DIY Duplicating Rig
Have been working on a neck/bridge duplicating machine for the past few weeks. First attempt was a POS and I lost interest but saw a better plan on Y Tube and resumed the project.
The 2nd effort uses a lot more roller bearings and runs a lot smoother almost with no resistance. Still somewhat of a kludge but less kludger(sp) that the 1st attempt.
I have to make a real clean and straight master neck to dup the next few days and then will do the 1st trial. Will also do a bridge. I have a 1/8" and 1/4" ball mill cutters, will try the 1/4" first and see how it goes. A few pics....
Bruce,
Bruce,
BEJ
Re: DIY Duplicating Rig
A few more pics....I'm going to use it to mostly carve the neck, will do the head stock with bandsaw/spindle sander and the base with router and guide jig.
TEETERFAN
Looks good! You certainly are putting a lot of effort. Hopefully your work will produce a useful addition to your shop!
Kevin Doty
Kansas City
Kansas City
BEJ
So true, spent a lot of time getting the right # of washers to best center the bearing on the conduit and to track without any slop. Must have reworked every part of the set up at least 2-3 times before I was alright with it. Sometimes like making tools/jigs more than making the guitars.
Planning to use the set up to RO about 95% of the neck and fine tune the rest by hand. Will see how it goes.
Bruce,
Bruce,
BEJ
An update on this project. After the 1st attempt neck the surface was pretty rough and I was disappointed in the results. Thus I set the rig aside, but in the long run I couldn't give up on it. So out it came.
Since building the addition on the shop I have a lot most space in the primary shop so I thought if I build a cart/stand for the duper and give it a second chance.
I had the wheels, drawer slides, drawer handles and some plywood already so it was nice to use this stuff instead of collecting dust. Just had to add a few drawers, never have too many.
I think I will add an1/8" or so all the way around on the dup pattern and do more filing/sanding out for final finish. ...a few pics.
Skarsaune
I've got one of the old Duplicarvers in the corner of the shop.
My brother-in-law picked it up but never used it - went to a pretty big CNC for his stuff.
Now it sits in the corner of my shop, and I still do necks by hand, sometimes on my CNC.
I had the same idea - there are a couple necks that I love, and I wanted to reproduce them precisely.
What I do now is just keep carving and checking with a profile gage I made. Its' working ok.
Bob Gleason
I also had one of those Marlin Dupliccarvers. It did not turn out to be practical for necks. A time consuming carver. I sold it to a guy who uses it to carver cement yard ornaments. Probably a better use for it!
