Back replacement
Back replacement
My client brought me her late Father's guitar. Not sure what happened, but suffice it to say, it needs a new back.
Re: Back replacement
Instead of using heat or moisture, I removed the old back by routing it off.
I new it was coming in, so I already joined a back, installed the black back strip, and installed the center reinforcement strip. I wanted to see the shape and size of the original braces before cutting and installing them.
The bridge was lifting, so I took advantage of the back removal to glue the bridge. The bridge popped right off with a chisel.
After taking the bridge off, it was a wonder that it hadn't come clean off much earlier. The entire outside 1/4" edge wasn't glued. On top of that, lines were scratched through the finish, ostensibly to give the glue something to hang onto, instead of scraping the finish off.
I scored around the bridge with an xacto knife, and cleaned the bridge footprint with the inlay tool.
I used hhg to glue the bridge. After clamping, I reheated it to ensure that the hide glue was hot enough to stick well. After I started doing this a few years ago, I've not had a glue failure.
Back is on.
