First Guitar Finishing
scamp
Post by scamp »
Will be starting my first guitar ( from a kit ) soon.
Doing a lot of research and I think I have a reasonable handle on constructing the guitar.
It all looks doable ( I"m sure I will make some mistakes but probably all reasonably recoverable).
After, however, looking at some info about finishing the final product I am a bit more concerned.
Seems like I need to make some kind of well ventilated area in my basement work shop ( with fans blowing air outside) and with relatively controlled humidity.
Additionally, it seems like rattle can spraying is tricky and buffing might require special tools ( car buffer etc.).
A fall back would be to hire someone to finish the guitar but I would like to avoid this if possible ( since it seems contrary to building ones own guitar).
So.. Does anyone have any opinions on how hard it is to finish the guitar ( setting up spray areas, working with spray cans, sanding, buffing etc. ) and if they were reasonably happy with the final results.
BEJ
Re: First Guitar Finishing
Post by BEJ »
You're about to enter the world of guitar finishing, about like entering "The Twilight Zone" good luck. About the only thing I haven't tried is Tru Oil, I have a bottle but need to make another guitar to try it. Seems like the least messy, simplest finishing method that meets your needs as stated. Robbie O'Brien has a good vid on Y tube on it's use, there are most likely some on this site too.
Bruce,
TEETERFAN
Post by TEETERFAN »
French polishing with shellac is a hand applied finish, no spray equipment needed. It will take a bit of practice to get the feel, but I was surprised how quick I learned the technique. Not as resistant to a spilled beer as lacquer, but a good looking result. Lots if stunning examples by other builders on this forum.
Kevin Doty
Kansas City
Skarsaune
Post by Skarsaune »
Lots of ways to skin that cat.
I spray rattle cans outside when the weather is appropriate.
I brush on water based finish in the house (no fumes).
French polish uses alcohol for the solvent, so minimal fume nonsense.
You can get a pretty darn good finish a number of ways. It might not be a factory slick clear perfect finish your first try.
Luckily for me, good enough IS good enough
jread
Post by jread »
My 1st was tru oil and it was easy and looks great. I moved to French polished shellac. It was a learning curve but easy to keep working it till it looks good.
My 2 cents….
They all look pretty much the same from >6’ away.
Factory perfect spray wouldn’t suit my builds anyway. I like em warts and all.
there are a few finishes that are not as smelly Tru Oil french polish and emtech 6000
carld05
Post by carld05 »
A matte or satin finish is another choice. Could eliminate the buffing step.
