More on the CNC Frontlines
After setting aside my wee CNC machine for the time being, to play catch up on guitar work, I delved back into it. I have a decent 3D software, but I needed a good 2D software for cutting out inlay and matching pockets. I bought Vectric's lowest level software, cut2d desktop yesterday.
I was encouraged when I found the make and model of my machine while downloading Vectric's software. I figured if they had my little machine, they must support the gcode in its entirety. Today I programmed a very simple logo, just 2 initials and a butterfly, then generated a tool path for an inlay pocket, and the gcode. This was the result. This is just scrap pine, which I didn't bother to take out of the machine or clean. But you can see the "CR" and recognize the little butterfly. They're actually a very cleanly routed pockets. Vectric generated the code which ran my machine with no errors or glitches whatsoever. The interface was very intuitive.
So, tomorrow I'm going to program it to cut out a couple of things for inlay.
Skarsaune
Re: More on the CNC Frontlines
I’m using Vectric’s VCarve desktop, one step up from the cut2d product.
Been doing logos also: The addition with moving to VCarve is you can cut a 3d part - can’t model it, but you can cut it. I did the neck profile on this one with it: Busy with full-size woodworking lately - made a rocker, chainsaw milling today, making shiplap tomorrow - along with the day job(s). Hope to get back on guitars more now that it’s cold.
I've cut out some shell today for the first time on the CNC. I'm getting used to it.
BEJ
Looking good, bet it's a lot easier on the wrist and hand, looks like you will be ready for some contract work soon. Maybe you could put a "J" on a pile of finished necks for me. Might be cheaper than buying my own machine and I wouldn't have to learn anything new....
sylvan
I have been using Vectric software for the past five years. It does everything I need or want. I have looked at many other software programs and none are as intuitive or easy to use as the Vectric products. However, I would seriously consider upgrading to VCarve Pro. It allows you to bring into the drawing a 3d object to utilize with your 2D drawing. With this capability, you can easily do fretboards and bridges in addition to all of the 2D projects that are possible. Lastly, Vectric gives you a full value trade-in when you upgrade so you have lost nothing trying the lesser products!
Sylvan
Sylvan
Sylvan Wells
Wells Guitars
Bay State Guitars
http://www.wellsguitars.com
Wells Guitars
Bay State Guitars
Skarsaune
VCarve desktop lets you import 3D models and machine them as well.
Biggest thing I see with Pro is unlimited size projects; desk top limits you to 24x24 IIRC.
Product comparison page:
https://www.vectric.com/products
And yes it's super nice that the cost to upgrade is like trading in your old software at full price.
rcnewcomb
Regarding Pro vs. Desktop offerings for Vectric, Pro adds support for gadgets. The Fret Board Maker gadget is free, and can do all the standard layouts. It also supports multi-scale and, if you have Aspire, compound radius. It works with versions 9.5 through 11.
- Randall Newcomb
Do you have a horizontal spindle on your cnc to cut the fret slots with? If not, how do you do it?
I won't be slotting, but I will be inlaying. If I were to slot, this is how I would do it on my machine:MaineGeezer wrote: ↑Mon Nov 08, 2021 7:05 pm Do you have a horizontal spindle on your cnc to cut the fret slots with? If not, how do you do it?
I don't know how your cnc is set up, but on my cnc, the gantry holding the router is on the x-axis, therefore my cnc cuts on the x-axis. The table advances on the y-axis.
I would align a fretboard along the y-axis, so that my cnc will cut a slot across the board on the x-axis, then the table would advance on the y-axis to the next programmed slot where the spindle would cut another slot across the board.
You'd have to use a mighty small bit. Most fret tang is .019-.023". That's smaller than 1/32".
Skarsaune
Precisebits.com has a pretty good selection of fret slotting bits.
https://www.precisebits.com/products/ca ... cutter.asp
No need for a horizontal spindle - you use an end cutting bit, not a saw to create the slots.
Runout in the spindle is super important at this small of a size. Another reason to use a spindle with real ER style collets instead of a router with router collets.
I have a router and a selection of fret slotting bits and will be cutting a test fret board as soon as I get some round to-its.
