Roping the Binding Jig
RHayes
Post by RHayes »
I didn't have the confidence to use the traditional roping of the binding and had already routed all the ledges for binding and purfling both front and back. This holder doesnt allow the cord to damage the 3 quarters not being worked on and you simply use which ever side required. This is going to save me a fortune in tape!! :) and no pulled fibers from tape removal. I had a box of 1/4 x 1" rivets so used them 1-1/2" apart. Saw something like it on line where 1/2" dowels were used at 2" apart so lots of possibilities.
Re: Roping the Binding Jig
there is always another way to do the same thing
if it works that is all that matters
thanks for sharing
jread
Post by jread »
That's really neat. I don't mind stocking up on stretchy tape and use shellac to seal which solves the fiber pulling. But man, it seriously takes me an hour or more to lift the tape off and clean it up. This looks fun too.
RHayes
Post by RHayes »
It really did seem fun and look forward to using it again. I just wanted to add that in drilling the holes in the edge of the plywood, an awl and regular machinist bit was used and the plys would make the bit move a little. Toward the end I decided to use a dowling jig with a guide bushing and the holes were nice and uniform.
I've done the same thing. It works great at pulling in the waist and corners of the bouts, the usual problem areas. Thanks for sharing.
