I'm working on the old Kay archtop, a good guitar to learn the art of restoration since I only paid $65.
I took the back off and replaced 2 braces, reglued one, and I've replaced binding. I'm in the process of resetting the neck. I took off the old fretboard to see what was happening with the neck. Well, it has no reinforcement, none whatsoever.
Luckily, when I took the old fretboard off, the neck straightened. It had a severe forward curve from years of string pull. The guitar is solid wood (surprisingly), but the neck is popular, not the hardest of woods, typical for a guitar out if Chicago of this era. I really wish to preseve as much of the original guitar and finish as possible, so it's necessary to add neck reinforcement. Since it's an archtop, a truss rod is out of the question.
I've decided to install a 1/4" steel rod, easy to do except the dovetail and headstock get in the way of the router jig I made to rout neck channels. On top of this, the neck is the old, thick V shape, pre WWII.
To use the jig, I needed to put the neck on top of a 1" piece of wood for support. But, trying to hold a v-neck steady while routing is a trick. I decided to use my trusty double-sided Duck carpet tape, but if any of you have experience with this tape, you'll know it'll take finish with it when removed.
I used the green 3M tape to first tape the back of the neck for protection. In my experience, I can trust this tape on old nitro and shellac. Masking tape will take finish with it.
After taping with the green tape, I attached my piece of wood, using the Duck tape. In that way, I could adjust my jig to rout down the center for the rod.
As you can see, it routed well and there's no damage to the nitro finish.
Learning Curve
Learning Curve
