Reinforcement strip for the back
Haggis
Post by Haggis »
Hello
The strip seem to be short. Is it supposed to reach the end/front blocks? It was delivered like this so I assume that it does´nt matter.
Häggis
Re: Reinforcement strip for the back
Look through your kit (I'm assuming you have a kit) there should be another strip, mine came with two. Make sure when you cut to length that the butt jiont falls underneath one of the back braces, then you won't have a joint showing somewhere in the middle of the guitar. I glued mine yesterday and I'm shaping them and notching them to glue the braces today (hopefully).
Post by Tony_in_NYC »
If there is not another strip in the box, call the kit maker. You need some more of that stuff.
where did you get that ? Was it off ebay ?
Haggis
Post by Haggis »
No I bought it from your company John, BluesCreek Guitars. I have looked through the kit..no more pieces
there should have been . They are taped together . is there enough for you to trim some off the top ? If not send address and we will get you a piece out
Haggis
Post by Haggis »
No there´s not enough material on the top. I´d be happy if you sent me a piece.
My adress:
Jonas Haggstrom
Hjalmarsnasvagen 25
68195 Kristinehamn
Sweden
I have another question though. Should I pull the piece above the soundhole as well? Se picture.
It´s a gap under the ruler and it feels like the same problem as earlier. But that piece is almost flat, just a little radius. I don´t know if it would help.
I have glued another set of x-braces, and I´m pleased with the results.
thanks
Häggis
can you get us a better picture of prespective? Maybe a bit farther back. I will send the piece tomorrow
john
Haggis
Post by Haggis »
Hope this shows it better. Klick on the pictures to zoom in on them.
Its tough to tell in the picture, and I know you posted a couple, but the should be a gap like what you show. It is part of setting the neck. Here is a great article explaining why it is there from Ken Cierp:
http://www.kennethmichaelguitars.com/neckangle.html
If the gap you have correlates to being part of the angle you need, you are good to go. If not, well...back to the drawing board you go.
