Martin Jumbo - Rosewood Kit
Re: Martin Jumbo - Rosewood Kit
I would remove the brace and put it where it fits.
Where did you get that design for a neck block? I've never seen anything like it (which isn't saying much, because my experience is limited).
Any neck block I've seen has been a simple rectangular block. I think you could cut off that extension that is interfering with the braces and be none the worse. A gazillion guitars have been built without any such addition to the neck block. I would NOT cut the top braces.
But I'd like to get the opinion of somebody like John, who has extensive experience with guitar construction.
That looks like most martin neck blocks I've used (kits or seconds). If this is your first kit, I would go with your idea of notching the popcycle brace to get a good joint with the top. Just remember to space this stuff out before glueing your next one up.
That's how I make my own neck blocks now, but extended to meet the USB (brace). Makes a pretty ridged system when the fretboard extension is glued down.
Re-reading this string....that is the correct way to fix it. Put a clothes iron on the brace and it should come off fairly easily with a bit of encouragement with a thin blade, assuming you're using a heat softenable glue.Cbstark46143 wrote:I would remove the brace and put it where it fits.
Clean the surfaces well and reglue it where it's supposed to be.
Not a big deal. This is why you use reversible glue when building a guitar.
that is a martin neck block you can cut that piece off. The cantilever is actually a glue caul . It is cheaper to design that than to pay the floor person to fumble with the caul , so it is safe to remove.
Well, I cut the cantilever off. No more conflict.
I’m back to building after a few days off. Now working on attaching the back.
For anyone interested, I had a whole separate issue with the back braces. You can read about that here:
viewtopic.php?f=3&t=9133
The back is dry-fit and the sanding of the kerf went well and looks tight for the inside. As you can see I the photo, the back brace in the center is not long enough. Maybe I set it too far toward the tail of the guitar, but I placed it according to the marks on the back. Oh well. I don’t know if it’s a big deal, but it’s too late now.
you need to taper the ends so the fade to the back plate. If they are heavy there is a stress riser and the brace will be loose. The fact is you most likely got a 000 back brace set and they are too short. It will work and still sound like a guitar.
I will contact Martin again. These back braces have been a fight for me. I have two other kits, so I would like the correct back braces for those kits.
Do I need to taper the ends of the braces to meet the back even if they don’t touch the rim?
So, here’s a dri-fit if the neck to the body. I have done no sanding of the wedge and look how recessed it is.
