Glue and the bridge
Danl8
Glue and the bridge
I need to re-glue a bridge. Fish, hide or titebond original. What should I use?
Re: Glue and the bridge
It depends on what was used orginally
Be sure all old glue if off and your on good solid wood.
Tite bond is a great all around glue
HHG is also great
Fish is ok but can be hard to get a bridge off .
the key to this is be sure your on clean wood.
Clamp time I do 24 hr no matter what glue
on torrified a weekend is my plan
HHG is also great
Danl8
Thanks, John. Titebond it will be. Original gluing was HHG -- in this case not done well (by me), but the joint failure was exceptionally clean and we are now down to bare wood ready to go.
use a little white vinegar to help get all the old glue out of the wood fibers
make about 4 part water 1 part white vinegar or use glue deegoo
Is this only for hhg?tippie53 wrote:use a little white vinegar to help get all the old glue out of the wood fibers
nope most wood glues will soften and make removal easier
Danl8
Good suggestion, John. The Q-tips & vinegar definitely picked up something, so it is ready for gluing.tippie53 wrote:use a little white vinegar to help get all the old glue out of the wood fibers
