Hi I need to make some radiused cauls for my stewmac 000 model back. I don't own a band saw and I am not planning to get one anytime soon, so I was wondering if there are any recommendations for creating these?
My current approach is to roughly cut with a hand jig saw and then plane and sand it.
caul making tips?
Re: caul making tips?
you can use a deck of cards and fan them out for the radius
Before getting the concave sanding dishes, I used 1/8" steel cable (doesn't stretch), 16', anchored one end and drew the curve on both sides of boards then used a coping saw to cut the curve. I did a couple of boards and made a lamination. Belt sander made quick work of smoothing. Now don't use it except for backing when gluing braces sometimes (mostly use the dishes on the go-bar deck).
You need 2 things go make an arc of a circle without having a 29 foot string
First is sagitta of the arc = the distance off a baseline the arc will be. And to get that, use this :
https://www.mathopenref.com/sagitta.html
Second is an easy way to make the arc. Here you go (sorry - the forum only allows one URL - piece this one together):
flickr dot com slash photos/ruby1638/9566635434/in/album-72157635172644427/[/url]
and here is a batten in use, both as a sanding batten and as a caul. I just cut these out of an older (stable) 2X4 on the bandsaw and then 60 grit sandpaper on a rubber block to even them out. Stick sandpaper on the batten for a sanding batten, leave the sandpaper on for help in gluing when you use it as a caul.
1) shows the amount of "sagitta" or offset in a 15' radius, 24" long beam. Note the 1/2" bolt/pivot
2) shows sanding - the bolt that comes up out of the baseboard is not installed in this shot
3) shows clamping against for back braces
Sorry - this forum only allows 3 pictures or I would show you how the braces are shaped against the same batten. After 9 instruments I still don't have a dish or a go-bar deck and won't pursue either. It just take a minor amount more time to do it this way
Thanks for the comments - actually drawing the arc isn't the problem as I can just trace the shape from the pre-cut braces that I am using.
The issue was really is there a way without a full band saw to cut cauls to the shape of the arc.
