Bending Curly Cherry
Have John's Bender. Have had good luck bending maple - should I use the same procedure for curly cherry?
About 325 - very little water.
-Jeff Jewitt-
Jewitt Guitars
www.JewittGuitars.com
Homestead Finishing Products
www.homesteadfinishingproducts.com
Jewitt Guitars
Re: Bending Curly Cherry
I've bent a few cherry sides, and it has always bent pretty well. I don't think it's considered a difficult wood to bend. If it is extremely curly, that might add an unknown amount of difficulty. My guess, however, is that you'll do fine. Lacking better information, 325 with a bit of water sounds to me like a reasonable thing to try.
Maingeezer is correct
Just had an experience bending curly cherry. I found the wood I had very cooperative. Operator error scorched one side, I had placed the thermocouple between the wood and the lower slat, and caused excess heat in the blanket. Oops. But the wood itself, mine was very cooperative at .080".
For extremely curly woods I have been spraying both sides with Super Soft veneer softener, wrapping in foil (taking care to keep the foil smooth) and bending with a heat blanket. No cracked curly sides yet with the super soft.
I use plain water, lightly sprayed, on both sides. I've never had a problem.
Yesterday I bent a pair of curly cherry sides .080 thick, quite successfully at 300 degrees Fahrenheit. I bent the waist on a pipe, the rest in the bender.
I use windex instead of water for most all wood anymore
Some woods if you have spring back you can heat to 375F then drop to the dry heat cycle of 220 275 F
I do lower bout upper bout then waist the pulling down of the waist helps to lessen the spring back as you
get a tighter press that way but as we all know , it all works in the end get wood hot it bends. the mold will set
the final shape and the bender helps keep coffee warm in a pinch
Windex, interesting!
