useful inexpensive router
Post by phavriluk »
I had a HF trim router in inventory and didn't know what to do with it, its bearing runout spooked me away from 'serious' uses.
But I found what to me is a wonderful timesaver: I dedicated a flush-cutting router bit with a bottom bearing to the router and I use it when I trim overhangs from the soundboard and back. Router and bit cost less than thirty bucks and I spend zero time setting up the router for the job, it stays set up. The runout isn't noticeable and I get nicely trimmed overhangs very quickly.
There's times where good enough is just fine.
Re: useful inexpensive router
best luck to you I had one that threw the bit and destroyed a set of Brazilian wish you better luck
Post by phavriluk »
John, that's a nightmare of a story. Thanks for the heads-up.
Peter that is a great idea with inexpensive tools. Just to say, I routed the binding channels on my first 6 guitars with a harbor freight trim router....never had an issue and I bought two more of them (on failed at the collet). I know have a Porter Cable and a Dewalt, but the HF's are for back up.
Post by phavriluk »
Another inexpensive tool: chisels. We can go broke buying them and their sharpening stones. I got lucky last year when I bought a set of chisels at Aldi. Eight bucks for the set of four, and they sharpen nicely and hold a decent edge. But that's possible only when someone's lucky enough to be visiting Aldi when the chisels are there, I suspect for nothing longer than a few days, and otherwise wait till sometime next year.
And we all know about block planes....
I have a ton of vintage chisels and block planes I will sell at reasonable prices - these are 2 tools that seem to be everywhere.
Bob Gleason
Post by Bob Gleason »
I think the Rigid Home Depot trim routers are worth the extra $. Only issue I have had is needing new brushes occasionally. I think they still come with a flush trim bit.
