Rosewood Back Seam Seperating
I'm wet sanding, and it appears that the back joint, near the tail end, is opening up. I can feel the seam with my fingernail. Have no idea what to do about it. Advise? It's nitrocellulose lacquer finish, 12 coats.
Measure Twice,
Karl B
Karl B
Re: Rosewood Back Seam During Prep
is it open or glue shrink?
Looks and feels open. I can feel it with my fingernail, and it has liqueur slurry in it. The back was glued at least a year and a half ago. How would I tell if glue shrink?tippie53 wrote:is it open or glue shrink?
Measure Twice,
Karl B
Karl B
if it is cracked you can press your thumb on one side and feel it move
I think you have glue sink . Did you use a filler?
I did use use filler, Aqua Coat over Behlen vinyl sealer. Aqua Coat about 5 filling sessions.tippie53 wrote:if it is cracked you can press your thumb on one side and feel it move
Measure Twice,
Karl B
Karl B
good
check that it is an open crack use naphtha and see if it wicks into the wood that you can see it from inside.
