Installing frets on or off neck?
ChuckBarnett
Post by ChuckBarnett »
My first build is a tenor ukulele. Working on a maple fretboard with narrow frets. Are there pros and cons to installing frets with the fretboard glued onto the neck or separate? I really have no intentions of appearing as an example of what not to do in this case.
Very gratefully,
Chuck Barnett
yellowesty
Re: Installing fretsh on or off neck?
Post by yellowesty »
FWIW, I just finished installing frets on a guitar I'm building after a year of non-building. So I forgot whether I should install the frets before or after attaching the soundboard to the neck -- and, unlike you, I didn't have the patience/foresight to ask.
I attached the soundboard to the neck before installing frets. I'm sorry that I did. The frets over the "straight" portion of the neck installed easily with a press and cauls. The frets under the soundboard extension (clear of the truss rod) pressed in easily as well. The frets in the region of the neck heel were far less easy.
Next time I'll install the frets before gluing the fretboard to the neck.
I install the frets after gluing the fingerboard to the neck and before shaping the back of the neck, i.e. while the neck is still rectangular in cross-section. I press in the frets, and having the neck rectangular gives good support while pressing -- or while hammering, for that matter.
Installing the frets after gluing the fingerboard to the neck also helps keep the fingerboard flat. If the frets are tight, the fingrboard can curve dramatically from the wedging action of the fret tangs.
But I think the main thing is to find out which way you feel most comfortable doing it, and get good at doing it that way.
Post by phavriluk »
I've done one each, fretting off the neck and fretting after installing the fingerboard and shaping the neck but before finishing the neck. I found cleaning all the finish that made its way past the masking tape on top of the fingerboard to be a good way to burn an evening. Next up will be fretting after the neck is finished. Somewhere I'll find the most comfortable workflow for myself.
