another commission and class this week
been hard at work teaching and completing a commission. The commision is using Bruce Petros's purflex . It is inteterseting . This guitar will have a celtic theme.
Pat Pope is making a OM 18 ad you can see by the pics it is coming out well.
Danl8
Re: another commission and class this week
Post by Danl8 »
John,
That's going to be a beautiful guitar. Is the top cedar or cooked (Maillard-style) spruce? The three-piece back is really striking.
-d.
the top is torrified red spruce
finished up the purfex I used the suggest epoxy and it is curing . I can sand in the morning to get ready for finish . I used a heat lamp to hold the epoxy at about 85 degrees. This sped up the cure time .
Good idea to put the epoxy in a squeeze bottle.
I found that sanding the epoxy tended to embed black dust into the surrounding wood -- especially the spruce top -- and make it look dirty. A chisel, block plane, or scraper produced shavings that did not embed.
also what I didn't tell you was that I sprayed 2 coats of lacquer on the top and back to avoid the dust contamination.
Also be very careful as you can sand through this easy
tippie53 wrote: Also be very careful as you can sand through this easy
Yes! I managed to do that with the Purflex rosette on my 2nd guitar build. The actual pattern of the Purlfex is only 0.040" thick, I think.
What wood is the purflex guitar - Tasmanian Blackwood or Koa? Or other?
koa with a sycamore binding and back wedge
It looks great. I've not used purflex yet. I like the look.
