Headstock Inlay Adhesives
IRISHPICKER
Hi,
Happy New Year and hope everyone had a great holiday. I am getting ready to install an in lay on the headstock and was wondering if there is a preferred adhesive for the task. I have seen everything from Tite-bond, CA and epoxy glues, just wondering what everyone else uses and if one has any significant benefits?
Thanks in Advance,
Pat
Thanks in Advance,
Pat
Re: Headstock Inlay Adhesives
what is the veneer? Rosewood I use super glue
here is a video of what I do
https://www.youtube.com/watch?v=o7gYBqLRdMo&t=758s
Gibsonman
What about Ebony John ?
same thing
CA is my glue of choice on small inlay epoxy with tempra on large inlays
I don't do much inlaying, but I usually press in in the inlay then put a drop of water-thin CA glue (StewMac's #10) on it, making sure the glue flows over the edges of the inlay so it gets into the joint. If the inlay is a tight fit not much is going to get in to the joint, but I assume it doesn't take much to hold the inlay. None have fallen out on me so far....
I put the inlay into place, wick thin ca glue around it, then toss wood dust over it. After shaking off the excess dust, I sand the buildup down.
Danl8
BTW, nice inlay, Diane. Really good fit; looks like the pieces were CNC'd into place.Diane Kauffmds wrote:I put the inlay into place, wick thin ca glue around it, then toss wood dust over it. After shaking off the excess dust, I sand the buildup down.
Thank you very much! Like everything else in life, there's a learning curve.Danl8 wrote:BTW, nice inlay, Diane. Really good fit; looks like the pieces were CNC'd into place.Diane Kauffmds wrote:I put the inlay into place, wick thin ca glue around it, then toss wood dust over it. After shaking off the excess dust, I sand the buildup down.
