Martin Top radius
jbjewitt
Martin Top radius
Post by jbjewitt »
I read somewhere that Martin switched from a 40' to a 28' radius (which they use now) at some point. Do you know why they did this?
Am building a 00- 14 fret SS maple/sitka and was thinking of a 40' top Any issues with it?
Jeff
-Jeff Jewitt-
Jewitt Guitars
www.JewittGuitars.com
Homestead Finishing Products
www.homesteadfinishingproducts.com
Re: Martin Top radius
Just guessing, but I imagine it was to reduce the tendency for the top to crack with changes in humidity. A curved top will rise and fall. A flat top has no place to go.
A curved top will also, I think, better resist deformation from sting tension.
I am just guessing though. I may be way off.
I am an authorized Martin shop . Since we don't have the Martin assemble fixtures we find that a 28 foot
Martin uses about a 52 foot radius on the braces and they put a 1 1/2 degree angle into the sides for the neck angle .
https://www.youtube.com/watch?v=LrgRKKsxL-M&t=1130s
there is a slight dome in the side also . I find that this video works the best for me to attain the 1/2 in string height and the proper neck angle
