I've had trouble bending binding with the bending iron. The spring steel that I had was too long to control.
I made a jig (I guess that's the right term), to hold the binding on both sides. I have the one pictured, which is one stewmac bending strap, cut in half. The 2 halves are held together with a wingnut and bolt. I also have another set, which is 12" long, but half the width at 2" wide.
I can bend 4 pieces of binding at once. It makes it much easier to hold them level and straight. I simply loosen the wingnut to move the jig down to the next bend.
This is curly maple. I didn't use any water. After bending, I clamped them into the mold. There are no breaks or bends from the curl.
I take the screws out and use the shortened bending strap to bend sides. It's much easier for me to control a 12" strap, than the 24".
Bending binding
Bending binding
Re: Bending binding
great solution
Danl8
Re: Bending binding
Nice! I like the handles -- very practical.
Re: Bending binding
Actually, I think it's a fixture, not a jig, but EVERYBODY gets the terminology wrong including me so don't worry about it. I think it's like this:
Using machinist definitions, a fixture is some sot of workholdng device. A jig is used to locate holes for drilling. For example, you might have a fixture designed to hold a guitar bridge on your drill press table so you can clamp a drilling jig to it to properly locate the six bridge pin holes.
...at least, I think that is correct.
That's what a metalworkiing machinist would say. Woodworking may use different definitions of the terms, of which I am totally unaware.
Kbore
