replacing split neck block
I have a conversion we are doing in a class this week. I have heard of it but this is the first time I had to deal with a split neck block. There was some poor work done on this before we started. There was a screw that was in the side next to the neck and I suspect that may have helped to split it. Regardless here are some pics on how I got it out. I first drilled a few holes to help steam the block . We also had a crack in the side so we taped that to help stabilize it while working on the block. Steam helped some but in the end I used an iron and heated from the out side. Knowing we are doing a refin I used any access I could. We are also replacing the back strip so I could use that area for holes. Took about 45 min but we managed to get it out and clean up the area, I did cut off the front of the original block and glued it to the replacement.
I will notify Martin of the neck block repair for the q list.
Kbore
Re: replacing split neck block
Post by Kbore »
tippie53 wrote:I did cut off the front of the original block and glued it to the replacement.
Sweet.
Measure Twice,
Karl B
getting closed
we closed the box today
routed out the old 28 style back strip and set in the new old style 40's style back strip
this is the end product
came out better than planned
