Tuner Restoration
Tuner Restoration
The 000 has an original set of working tuners. How do I get rid of the rust safely and clean them up?
Re: Tuner Restoration
You could try some stuff called Evapo-Rust. http://www.evapo-rust.com/ It's environmentally safe and in my limited experience works reasonably well.
I would remove the tuner buttons before soaking the parts. And, of course, keep an eye on things.
Thanks Steve. I'll check it out.
