What are the approximate overall dimensions used for Martin neck and tail blocks? Do they need to be quarter sawn? I know there's a big debate over grain running perpendicular vs parallel to the side grain...but I don't see where how it's cut is that important that I can't just thrown some mahogany in there. Thoughts? Thanks for the help!
V/R
Neck and Tail Blocks
twenty2late
Re: Neck and Tail Blocks
the blocks changed during the years
I use the old heavier block 1 9/16 thick
3 in wide
grain running parallel with the sided
if you run grain vertical and use a dovetail you can split a block
tail 9/16 by 3 also grain parallel to side
I prefer face grain to quarter sawn
3 in wide
twenty2late
Thanks John!!! I just ordered a set for both dreds and 000s from Martin to compare. I will contrast that with those dimensions below. Face grain is perfect, because I can get that easily. Finding quarter sawn mahogany around here is apparently a real challenge.
V/R
V/R
