Thanks to John Hall
Intonation, Compensation, Frustration
colin
Thanks to John Hall
Post by colin »
Had an '82 D28 in for a refret (and side crack repair) which I've just finished.
Thanks to John Hall's advice, the required compression refret (and the supplies) has worked out really well.
Ready to go out the door with 12's on it, action 2.4/1.4mm (a bit less than 6-4/64ths), just enough relief not to buzz when played quite "firmly" in DADGAD (owner plays in a ceilidh band)
Many thanks John.
Re: Thanks to John Hall
so glad it worked out for you
