Hardwood top?
Michael Thoner
Hardwood top?
Post by Michael Thoner »
Anyone ever throw rosewood on for the soundboard? I've been thinking about trying it out.
Re: Hardwood top?
I heard an all BRW guitar from Mexico, it was pretty but sounded rather weak. Rosewood is a good sounding tonewood but it is rather dense for its stiffness. To make a top with the right stiffness you end up with a top about twice as heavy as it should be.
Koa works OK for a top.
Re: Hardwood top?
they are too heavy to make a good top .
Re: Hardwood top?
I think there have been guitars with mahogany tops, and I've seen very nice dulcimers with walnut tops. There are undoubtedly hardwoods that will make a reasonable guitar top...but not rosewood.
If you want to try it though, have at it!
Danl8
Re: Hardwood top?
Post by Danl8 »
Mahogany has been a fairly common top for guitars. I have two (pics posted here somewhere). The quality of sound is excellent, in fact, my daily player is one of the two. Other than Koa, not so sure other hardwoods, like the dalbergias would be acceptable. Maybe walnut?
-d.
Michael Thoner
Re: Hardwood top?
I know it's heavier, but what if I shave it thin?
Re: Hardwood top?
There is a ratio how stiff by how heavy. Rosewood is stiff but it is very heavy. If you make the top thin it will not be stiff enough and sound bad. If you make the top the correct stiffness it will be too heavy and sound bad. That is why it is not used as a top wood unless you want a wall hanging.
There maybe be things you can do with a plywood top, maybe thin veneer of rosewood laminated to spruce.
Re: Hardwood top?
the hard woods I know that were used and worked
Mahogany
Catalpa
Koa
Poplar
Sunset
Re: Hardwood top?
Post by Sunset »
This doesn't answer your question but I too was "cautiously" curious as to other wood types for a sounboard top as well. I decided to play it safe and stick with the traditional Spruce top until I gain further experience.
Interesting is that another instrument that utilizes a soundboard is a piano. Like CF Martin, Steinway & Sons have been at this game for a long time. I'm sure both companies have spent boat-loads of money researching and experimenting with alternative woods for their soundboards.
An interesting quote from Steinway's website:
"All STEINWAY soundboards are made with Sitka spruce, the most resonant wood available." -end-
Key words above are "the most resonant".
source: http://www.steinway.com/news/articles/t ... -richness/
Martin & Co. established in 1833
Steinway & Sons established in 1853
Sunset
Re: Hardwood top?
Post by Sunset »
