Tang nabbit!
Post a photo of something you are working on today. No need to explain or write anything. A photo is worth a thousand words. If you must write something caption your photo with the "File Comment" field when uploading an attachment. Keep it short and show us some photos!
Forum rules
Pictures please.
John J
Tang nabbit!
Post by John J »
My finger always gets sore holding the fret.
Learning every day.
Re: Tang nabbit!
do you use a tang nipper first or just completely file it off. The tang nipper is quick, maybe a bit messy but the file would clean it up lickity split.
http://www.stewmac.com/Luthier_Tools/Ty ... ipper.html
Danl8
Re: Tang nabbit!
Post by Danl8 »
I use the nipper. For the first two boards it cut so cleanly no filing was necessary. Maybe that will change with further use.
John J
Re: Tang nabbit!
Post by John J »
[quote="johnnparchem"]do you use a tang nipper first or just completely file it off. The tang nipper is quick, maybe a bit messy but the file would clean it up lickity split.
Yes I use a tang nipper. Thats just the final cleanup you're looking at.
Learning every day.
