Tenoning
Post a photo of something you are working on today. No need to explain or write anything. A photo is worth a thousand words. If you must write something caption your photo with the "File Comment" field when uploading an attachment. Keep it short and show us some photos!
Forum rules
Pictures please.
John J
Tenoning
Post by John J »
Lots 'o sawdust
Learning every day.
Re: Tenoning
Doesn't that router have a vacuum hook up? I switched to my table saw with a tenoning jig. The router was just to scary for me. I do use the router for the mortice.
Bob Gleason
Re: Tenoning
Post by Bob Gleason »
John, I cut my dovetails with a router. Would like to see an expanded photo of your set-up.--Bob
Re: Tenoning
I had done it a number of ways , table saw Milling machine and router. I do prefer the router . I do have a jig for the router. I can precisely adjust neck angle with the router jig.
I think any of the methods work as long as your process is well controlled.
John J
Re: Tenoning
Post by John J »
I've been using the jig from J. Simpson that I purchased through his eBay site. It works really well and only requires a bit of fine tuning. Initially the tenon is too snug for the mortise. That is by design. A little hand sanding and you can get a nice snug fit. I like the way that you set the neck angle. You can adjust for your particular bridge/saddle height target. I use my Dewalt trim router in the plunge base.
Learning every day.
