Recommended Pore Filler for Nitro on Rosewood?
B. Howard
Re: Recommended Pore Filler for Nitro on Rosewood?
Pore-o-pac would be a good choice. I always sandwich my pore fillers between coats of sealer.
I use Pore o Paw and use the vinyl sealer. I use mowhawk and Behlens products
Jasco is also pretty good.
I use natural so I can custom color the filler. I use Minwax stain ( the mineral spirit base ) works well with the Pore o paq. If you are trying to do a martin style color I use
1 special Walnut from minwas
2 Dark walnut
I apply this with a brush but have used old credit cards. I allow the filler to flash then start to rub it into the wood. I will examine it very close and look for missed grain pockets. If it looks good I do it one more time.
a few drops of each into about 3 tablespoons of filler and work this up with a plastic fork to get a mix similar to Hersheys syrup. Then I add a few drops of Naphtha into this to aid flashing. I do a side then the back. I will often stain the wood first then hit a coat of sealer. Then I do the filling and hit another coat of sealer .
2 Dark walnut
B. Howard
You should use the sealer that is recommended for under the finish you are using.mike288 wrote:Hey Brian, what sealer do you use, and how many coats do you use between the pore filler?B. Howard wrote:Pore-o-pac would be a good choice. I always sandwich my pore fillers between coats of sealer.
I use one wet coat under and one over the filler.
Kbore
Hey Mike, what did you end up using for your filler and sealer and how it it come out?mike288 wrote:Hi All,
Getting to the end of my build, and I'm wondering what type of pore filler I should use on my Indian Rosewood. I'm leaning towards Behlen Pore-O-Pac, since I'm doing a nitro finish. I'm wondering what you all think? Also, am I correct in not sealing the guitar before I use pore filler since I'm using nitro?
Thanks-
Mike
Measure Twice,
Karl B
Karl B
Kbore
Behlen Stringed Instrument Lacquer is very specific saying you MUST apply the Nitro over a (their) vinyl sealer, I'm a believer.mike288 wrote:.... I'm wondering what type of pore filler I should use on my Indian Rosewood. I'm leaning towards Behlen Pore-O-Pac, since I'm doing a nitro finish. I'm wondering what you all think? Also, am I correct in not sealing the guitar before I use pore filler since I'm using nitro?
Thanks-
Mike
You could apply Pore-OPac over or under the vinyl sealer, there are advantages to both depending on your method of work. Vinyl Sealer will also partially fill the grain.
Take note that if you don't seal first, then apply a tinted Pore filler, the filler will tint the entire wood surface, not just the grain. Do a sample on a like wood with and without sealer and you'll quickly see what that means.
Measure Twice,
Karl B
Karl B
