Built A Side Bender
Post a photo of something you are working on today. No need to explain or write anything. A photo is worth a thousand words. If you must write something caption your photo with the "File Comment" field when uploading an attachment. Keep it short and show us some photos!
Forum rules
Pictures please.
twenty2late
Built A Side Bender
Post by twenty2late »
That was fun...for a couple hours ;-)
Re: Built A Side Bender
What is the heating element?
twenty2late
It uses a 500W cartridge heater that is surrounded by 20ft of aluminum flashing. The plans to build it are in the book in the pic.
rcnewcomb
Post by rcnewcomb »
Is the pipe galvanized? There may be a health risk due to toxic gasses released when heating galvanized metals: Metal fume fever
- Randall Newcomb
twenty2late
It is galvanized...because that is all I can find. After a little research, it looks like the concern is mainly for welders who liquify the metal. Most sources state it is fine up to 700°F. I plan to be at 400 max. I'll do some outside testing first to be safe. Does anyone else have advice on this? Thanks for the heads up!
I doubt you need to worry about fumes. The surface finish may be more of a problem. I might be inclined to take some abrasive roll (the stuff plumbers use to polish copper fittings) or something similar and try to polish the surface so it is very smooth. I would wear a dust mask while doing so, to avoid breathing the zinc dust.
Sunset
Post by Sunset »
Pablo Requena has a great youtube video on he made his bending iron using only a light bulb as a heating element. Very interesting.
https://www.youtube.com/watch?v=-py9FGK ... 6s&index=1
