Another Fleischman-Williams Binding Jig
As a beginner I was a little daunted by doing the binding channels for my two "first" guitars. With the Canadian dollar worth a lot less, I couldn't afford to buy one of the fine looking jigs available. So I took a lengthy detour and made a close copy of the Fleischman-Williams jig using information posted by Williams and others. It was a lot of work but looks good. I did a couple of things perhaps differently so am sharing them in case anyone is considering this project. I used 1/2" UHMW plastic for the parallelogram side plates as the recommended phenolic was a special order. It seems a good alternative because it has some self-lubricating qualities. I used nyloc nuts on the bolts that run through the parallelogram arms so the tension can be adjusted somewhat. The bolts were rubbed with wax for a bit of lubrication. I added a one inch strip of plywood glued to the back of the plate that the router base is screwed to - this allows a couple more screws for rigidity. For the "donut" I used 2" UHMW "dowel". I clamped it vertically (using a Workmate) and profiled the end with a roundover bit (easier than I thought) then cut the profiled end off to the right thickness. This was located carefully on the new UHMW router base plate and screwed from behind. The base was screwed to plywood so it could be clamped in the drill press. Then I drilled a 1 1/4" hole through the donut and base plate. I used a spade bit (Speedbor) which was quite slow on my little drill press - a better bit would be faster and probably safer. If the donut is not quite right I can make another. Lee Valley is a good source: Got the 12" Lazy Susan bearing there (Oshkosh brand).They also carry knobs etc. for the cradle but a good deal is a kit they sell with a variety of knobs, T-nuts, etc., their part # 12K7990. I bought their small rabbeting router bit with extra bearings too, but have augmented this with a few more bearings from Stew Mac. When they arrive I can put the whole shebang to the test.
Re: Another Fleischman-Williams Binding Jig
Your machine looks really good. One thing I think I'm seeing is the opening in your donut for the bit to come through may be a big large as you really want the edge of that donut to just ride on the ledge of the guitar, maybe no more than a 3/8" or so. Not a problem on the top, but it can be an issue on the back with the bigger radius and the slant toward the neck. It seems you might be riding farther in on the top and back the way you have it, but then It may be fine, and it just looks bigger than it is?
should work fine
Kevin, the reason the opening is that size (1 1/4") is that the bit is 1" and Bosch specifies at least 1/4" larger than the bit for the hole. But I see what you are getting at, and it did occur to me that I could have rounded the donut less, leaving more of a shoulder for the donut to ride on (though that doesn't change the hole size.) As I mentioned, if it doesn't work right, it is not a big job (easier than I imagined) to make another donut with less roundover and more surface to ride on. I hope to try it out in the coming week, international mail permitting (waiting for bearings from StewMac) - Bruce.
Ohhh, okay, well that explains it and now I see why. I couldn't see the bit I guess. You did a great job on the construction.
Just a note to say that this tool worked as planned, though it did take a little getting used to - mind you, I was cutting my first binding rabbets on my first guitars. I had a problem (don't know why) with both my guitars having sides not uniformly perpendicular all around, so I had to fine tune by setting parts of the guitar so the side was perpendicular and then cutting. The cuts were more accurate and I was pleased at how well the jig worked when faced with this abnormal problem.
The Stew Mac bearings I ordered would not fit the Lee Valley bit set I bought. So I also bought the Grizzly set that added a bit, some more bearings plus bushings so I have a lot of possible combinations now - and less money in my pocket . . .
Nice job! Very well made.
Wow! Very Cool.
