adjusting neck height to lower action?
heman
Post by heman »
Hi, I am new here.
I recently finished my first kit build. It was a tele kit from Thomann (Harley Benton).
I replaced the bridge with a 6 saddle bridge, and that one was a bit thicker, so the action got higher.
Even when the saddle is as low as can get it it is about 2mm on the high E (bottom to 12th fret).
I tried to raise the neck a little bit by putting some paper (about 1mm thick) under the neck, to try to lower the action by raising the neck.
It didn't seem to have much effect.
I was considering two options:
1. putting more paper or something else (veneer?).
2. drilling the screw holes in the body a little bit wider so that the screws become loose in the body (now there is internal thread in the body and the neck). then there will be a gap between the neck and the body. The screw heads and metal plate will attach the neck on the body, and the internal threads in the neck.
Then the four screws could be used to raise or lower the neck as well as adjusting tilt.
other options could be to get a thinner bridge or remove wood beneath the bridge. Those sound less appealing to me.
Re: adjusting neck height to lower action?
you may need a bit more shim. Remember that if you want to raise the action you only shim the lower part ,this angles the neck up . Try that again using a small piece of veneer on the lower part of the neck joint. Even a pick does the job. Keep us posted
heman
Post by heman »
Thank you for your answer. I really appreciate it.
I'll try that, and keep you posted.
I posted a bit about this guitar including photos and demo videos in another guitar forum I frequent in case anyone is interested:
http://www.jazzguitar.be/forum/guitar-a ... y-kit.html
heman
Post by heman »
here are some photos:
http://imgur.com/a/b26Cw
(I realized that these photos can't be seen in the other link I posted)
