Fingerboard lacquer repair...
On a recent 000-28 build, when I was filing the fret ends, I got a little close to the lacquer finish w/ my file. Consequently, in a few spots, the finish got scraped/chipped down to bare ebony. Not quite sure how to go about fixing this? Whether I should sand, tape off & try spraying more lacquer on...or, sand & brush-on several coats & wait for a good cure before final sand & polish. The low E side is particularly worse than the other...
Re: Fingerboard lacquer repair...
you can drop fill but allow a few weeks to cure.
Bob Gleason
Post by Bob Gleason »
You can help avoid that happening in the first place if you remove the tape from the fretboard a couple of times during the finish process and scrape back the edge with a razorblade. In this case, you'll have to drop fill, like John said. It will take a number of applications to build it up.
