Glue on guitar body
Greg Martin
Glue on guitar body
Post by Greg Martin »
Hi Guys, this is my first post. I’ve been lurking for a while reading and learning.
I have a question re: finishing. I’m hoping someone might be able to help me.
I recently purchased a kit guitar, I’m really happy with the guitar it looks great but after applying a stain coat I am noticing the stain isn’t taking in a cpl of small areas. I think it might be where glue has been absorbed.
Any ideas what I can do to remove it and not that I have already added a coat of stain is it too late?
B. Howard
Re: Glue on guitar body
Post by B. Howard »
The glue will need sanded or scraped away. The stain can then be touched up and blended. Careful inspection of your work prior to finishing using a solvent like naptha or DA will help find these spots so they can be taken care of beforehand.
Greg Martin
Thanks Brian, I appreciate your help.
Just to clarify......you wouldn't recommend using Acetone for instance?
I was concerned that sanding would not work if the glue had penetrated the timber more than a cpl of mm.
B. Howard
Post by B. Howard »
Acetone will do more harm to your satin and really won't eat the glue. Glue doesn't really penetrate far into the wood, a few thousandths of an inch maybe.....
It does depend on the glue but I agree with Brian in that water based glues won't penetrate much and can easily be sanded clean
Greg Martin
Thanks fellas really appreciate the advice. I'll get busy sanding.
