Polishing Compound
Polishing Compound
Which polishing compound do you recommend for a final step when using shellac? Is Novus Plastic Polish 2 still recommended? I want to make sure that the product doesn't contain silicone. Do I need to order a product made for guitars?
ColestineGuitar
Re: Polishing Compound
Post by ColestineGuitar »
I'll chime in here with my own experience, though I will enjoy learning what others use.
The Meguiar's auto polishes work well, and they are free of silicone. They are numbered. For a final polish, try Meguiar's #9 Swirl remover. Works very well and has little, if any, abrasive to it, so it won't take out scratches. The #7 does have a little bit of grit, and will take out some fine scratches. The finish looks pretty good after #7, but following with #9 yields pretty results.
I have used these polishes, thinking my finish was complete, only to decide I was not done adding shellac. I was able to switch right back to shellac without any kind of trouble.
B. Howard
Post by B. Howard »
Novus #2 works well.
I use mazzerna and maquires #9
I got StewMac's polish kit of coarse, medium, fine, and swirl remover. I haven't used them extensively, but they seem to work pretty well.
I've also tried Meguiar's #9, which also seems to do a good job although I wonder whether it leaves anything on the finish that would interfere with subsequent finish applications. Initial testing suggests it's not a problem, but I still wonder.
Thank you to all who replied. I appreciate all of your answers.
