As noted in my construction blog, I made some Delrin pins to fill the tuner shaft holes to keep the finish out of them. (Teflon would probably be better, but I don't have any.)
Does that seem like a good idea? Is it even necessary? What do other people do?
Keeping finish out of the tuner shaft holes
Re: Keeping finish out of the tuner shaft holes
I either use a reamer to clean them out afterwards or run a drill bit through them. The biggest issue I have had is with an epoxy pore fill.
I drill mine after the finish is applied and leveled.
