Cleaning up glue squeeze-out around rim
David Mathis
Post by David Mathis »
I am working on my first kit build and just glued reverse kerf lining onto the rim with fish glue. Upon taking off the clamps, I see that I was pretty sloppy with the glue and would like to clean it up. What is the best way to do this?
Thanks!
Re: Cleaning up glue squeeze-out around rim
I use a combination of a scraper (some time a straight edge razor blade). I also use De-Glue goo http://www.de-gluegoo.com/ to clean things up. Especially on the outside after bindings.
Tarhead
Post by Tarhead »
Try a warm and wet (but not dripping) paper towel rolled up and left on the dried glue for a few minutes. Once it softens scrape it off with a plastic hotel room/expired credit card with one end trimmed to 90 degrees with the length so it can get into the corners. Fish glue is very soluble in water.
David Mathis
Thanks for the quick responses and helpful information. I will give these a try.
