#2 a 00 12 fret
Jcolvin
#2 a 00 12 fret
Just finished my #2! It's a 00 12 fret. Here's the specs:
-Honduran Mahogany b&s
-an unknown type of spruce top (it's much lighter in color than the sitka I used on my first, but who knows, maybe it's sitka)
-mahogany bracing on the back, spruce 5/16 scalloped martin style x bracing top.
-15' radius back, no radius on the top (I was just curious what it would sound like, so I didn't radius the top, thinking that the string tension would round it out just a tad)
-mahogany neck, compound dovetail joint, v profile
-25.4 scale length
-rosewood binding with maple laminate
-rope type wood purfling, as well as rosette
-ebony pyramid bridge 2 5/16" spacing
-gabon ebony fingerboard
-1 3/4"bone nut and 3/32" bone saddle
-tru oil finish -gloss body, satin neck
-grover open gear tuners
I learned a lot while building this one. I got the wood as a kit from someone on ebay, advertising it as a parlor with seconds from martin. I was hesitant because of people's advice on buying these martin seconds 'kits' (that is, don't do it). But it worked out. The wood, to my eye, is high quality, and thankfully the neck and block joint was a good match. I was nervous about the dovetail joint, as this was my first time working with it, but I have to give John Hall many thanks for his extremely thorough videos on the joint. Using his ACE technique, I was able to get the neck setup perfectly in about an hour. This was my first time bending sides, bindings, and purfling. I made a homemade pipe bender using a pipe and a small propane torch. It worked but it was quite difficult getting the sides just as I wanted them, and in the end, they're really not perfect. On the next build I may seek out another option for bending, but I'd rather not spend big bucks on a bending machine. I also learned some big things about staining and finishing in general. I stained the back and sides prior to assembling the box, thinking I'd avoid accidentally getting stain on the bindings and top that way, but I soon realized that wasn't going to work. Of course when I sanded the neck joint area flat, the stain came off with it. And then scraping the binding obviously took stain off as well. So I just sanded all the stain off. It left me with nice dark pores, which I actually think look nice, so it wasn't such a fail after all haha. But lesson learned. The gabon ebony is super nice and buttery feeling, I like it a lot. And I used the gold fret wire from LMI, which ended up being a real joy to work with, compared to the standard wire I used on my last build.
I'm used to the sound of my rosewood dreadnaught so when I first started playing this guitar, I thought it was too quiet. But the more I play it, the more I like it. It sounds especially beautiful when playing jazz or ragtime finger style tunes. It doesn't have much bite, it's a pretty mellow sound. I don't really like the sound I get when flat picking it, but then again, I'm used to flat picking a dread. It's a gift for my wife for valentine's day, and I did all the building at 'the office', so she was pretty excited when I came home with it all done. (Now I just have to make sure I don't play the thing more than she does)
-25.4 scale length
Re: #2 a 00 12 fret
Great looking Guitar! That is my favorite guitar shape, including 12 frets too the body. Also a very nice gift. You still had a couple more days!
Danl8
Re: #2 a 00 12 fret
Beautiful, elegant guitar! The 00-12 fret is such a refined classic -- you've done well. How does it sound?
-d.
-d.
Re: #2 a 00 12 fret
Looks really good. A cute little guy!
Re: #2 a 00 12 fret
I think it turned out great! Wow, what great Valentine's Day gift. A 00, 12-fret is my next build.
Chuck73
Re: #2 a 00 12 fret
Nice work!
Jcolvin
Re: #2 a 00 12 fret
Thanks for the kind words everyone! I uploaded a couple of photos of when I was realizing I stained in the wrong order of events haha. One photo shows the neck joint after I sanded flat the body in order to get a nice flush fit, and therefore sanded away some stain. Another photo shows what happened after I started scraping bindings. I mean really...what did I expect???
Jcolvin
Re: #2 a 00 12 fret
Here's two more photos. One is showing my fretboard clamping setup. I made a caul with a piece of plywood and two 1/4" fiberglass dowels, angled to follow the outer edge of the board, to make sure the edges of the fretboard had good pressure. The other photo is one I used from a past post from John Hall (Thanks John!), and is where I took measurements to shape the neck.
