Homemade precision rosette routing jig
I got a second hand stewmac Drexel router base awhile back thinking I would purchase the stewmac rosette circle cutting jig someday. I begin looking at pics of some other ones available and thought I should be able to make one. I already had some pieces of 1/4" Plexiglas and some screws and bolts. I spent about $6 more dollars on parts and in about 2 hours I had it done. It works great and even with 1/4-20 threads the fine adjustment should work good. Adjustment is about 3.5 inches to 6 inches. It could have been made with a greater range.
So beats the $84 plus shipping that Stewmac is getting for there's and I had fun figuring it out too.
Re: Homemade precision rosette routing jig
Nice! Any chance you would feel like posting drawings of the design?
looks very nice
Frugality is the mother of invention....yeah!Kevin Sjostrand wrote:So beats the $84 plus shipping that Stewmac is getting for there's and I had fun figuring it out too.
I'll put a copy of my drawing and parts list
very nice, Looks like a really good range with a nice clean design.
Love to see a parts list....and a drawing. Thanks!
Here is the simple drawing I made to help me as I went. You could adapt it to any size to fit your needs.
The tool picture is what I found that inspired me to make mine.
The parts list I used is as follows.
2 @ 1/4-20 barrel bolts that are 3/8" x 3/4" long. I bought a few of these and I'm going to start using them on my mortise and tenon bolt on necks instead of using threaded inserts. I have since found some online where the hole is in the center of the barrel, unlike these where it is offset. For this purpose, that worked out better.
About 2" of 3/16" rod
1/4" bronze bushing (3/8" outside dia)
1/4-20 bolt, washer and wing nut for locking
3" long 1/4-20 threaded rod
1/4" lock collar
Threaded knob and a locking nut.
Hardened 1/4"x 1 1/2" long pin for the centering pin.
I also put a bushing in the workboard for the pin.
The slot for the locking bolt is 1/4" wide.
The slot for the top sliding adjusting part is 3/16" wide. The is because I drilled 3/16" holes in the bottom of both barrel bolts and press fit in a section of the 3/16" rod. Then I drilled a 3/16" hole in the base for the threaded barrel bolt and in the end of the top sliding part for the barrel bolt that is drilled out to 1/4" so the threaded rod can slide through it. These are just pressed into the Plexiglas. I later wicked in a little CA to help them hold but they go in very tightly.
That is pretty much it. The length of the slots and the distance of the centering pin to your routing bit will determine how small and how big a circle you can cut.
I cut the slots on my drill press using the router bits needed. I double side taped the Plexiglas to a piece of MDF the exact same size and clamped it into a cross vise on my drill press table, enabling me to cut them as you would on a mill.
This is a quick and dirty explanation, hope it helps.
Fun to make pretty easy too.
1/4" lock collar
Benjy
Thanks for posting this! I made a circle cutter today. I used a polymer cutting board from Wally world as the base.
Hey Benji just saw your post. How did your jig turn out? Any pics?
