taking off a bridge
taking off a bridge
I have been doing this cold for years. It only takes a few minutes and often faster than with heat.
https://www.youtube.com/watch?v=TYg8sEjxgpc
Re: taking off a bridge
That is amazing it sure came off clean, I have heard this method described but I have never seen it done. Do you always take off the bridges this way?
pretty much , it works well for me.
turnertj
Post by turnertj »
John...
Do you recommend the same method if the bridge was put down originally with Titebond?
The very first guitar I made was with titebond, and the bridge is lifting...
Tj
Tj Turner
Author, Scientist, bumbling Luthier
Author of Lincoln's Bodyguard
www.tjturnerauthor.com
yes just light taps and after a few cycles it will let loose.
nehsgolfer
Post by nehsgolfer »
If, when taking off the bridge, the wood underneath is really chewed up, is it possible to rout out the footprint of the bridge and glue in a new piece of spruce to glue the bridge to?
depending on the severity of the damage you may be surprised at what can be fixed
viewtopic.php?f=59&t=6956
B Shuler2006
Post by B Shuler2006 »
Daggone! You can have a bridge off by the time you would have gotten it heated up!
Brandon Shuler
Shuler Guitars
sylvan
Post by sylvan »
John -
The video was not clear and (at least on my computer) did not show the end of the chisel you used to take the bridge off. Would you please post some clear shots of the chisel? I loved the method! See you in June at the ASIA Symposium!
Sylvan
Sylvan Wells
Wells Guitars
Bay State Guitars
http://www.wellsguitars.com
I use a long firmer or paring chisel. I lay the flat side down. I lightly tap this. After about 4 times around it starts to pop. The key is patience and light taps. I find a 1/2 in wide chisel is about perfect. David Nichols showed this to me a long time ago.
I will try and get some pics the next time I take one off.
